- Wakefield Show 2024 in Pictures (News:1)
Acorn Arcade forums: News and features: Adventures in Optimisation - Walls
Posted by Jeffrey Lee on 09:00, 25/5/2020 | ,
The initial code
loop
The goal
The obvious problems
The final code
vline routines
mvline routines
tvline routines
Non-power-of-two
loop
Profiling results
The basics
XScale187.686.12.18x
ARM1149.743.61.14x
Cortex-A768.723.42.94x
Cortex-A8119.333.13.6x
Cortex-A917.816.91.05x
Cortex-A151811.71.54x
Cortex-A5346.516.82.77x
Cortex-A7218.39.81.87x
XScale187.6182.61.03x
ARM1149.748.91.02x
Cortex-A768.715.54.43x
Cortex-A8119.324.84.81x
Cortex-A917.816.71.07x
Cortex-A151816.61.08x
Cortex-A5346.511.34.12x
Cortex-A7218.311.71.56x
XScale187.610.917.21x
ARM1149.715.43.23x
Cortex-A768.7116.25x
Cortex-A8119.38.414.2x
Cortex-A917.86.72.66x
Cortex-A151844.5x
Cortex-A5346.59.94.7x
Cortex-A7218.34.34.26x
Blocks
XScale182.6253.60.72x
ARM1148.981.80.6x
Cortex-A715.519.60.79x
Cortex-A824.820.11.23x
Cortex-A916.737.40.45x
Cortex-A1516.619.60.85x
Cortex-A5311.316.40.69x
Cortex-A7211.7101.17x
rect4x4 variants
Different block sizes
C versus assembler
CPUvlineasm1_linearvblockasm
XScale10.928.6
ARM1115.412.9
Cortex-A7119.5
Cortex-A88.49.5
Cortex-A96.77.2
Cortex-A1544.1
Cortex-A539.96.5
Cortex-A724.33.7
Now add masking
Masking experiments
Masking block sizes
Translucency
Translucency experiments
Final figures
ARM1112.913.314.814.850.450.5
Cortex-A97.28.39.48.319.420.1
Cortex-A536.587.98.119.921.6
Cortex-A723.73.93.94.18.99.3
What we've learned
Footnotes
  Elesar (20:17 25/5/2020)
  Phlamethrower (09:41 26/5/2020)
    Kuemmel (12:49 26/5/2020)
Robert Sprowson Message #124856, posted by Elesar at 20:17, 25/5/2020
Jeffrey Lee Message #124857, posted by Phlamethrower at 09:41, 26/5/2020, in reply to message #124856
Michael Kübel Message #124858, posted by Kuemmel at 12:49, 26/5/2020, in reply to message #124857
