- Wakefield Show 2024 in Pictures (News:)
- April 2024 News Summary (News:)
Acorn Arcade forums: News and features: PackMan in practice
PackMan in practice
Posted by Jeffrey Lee on 09:00, 14/9/2018 | , , ,
PackIt's output
The actual package content
PackIt's Copyright tab
Automating package building
Before
CC = gcc -c $(CFLAGS) -MMD
LINK = gcc $(CFLAGS)
SRCS = \
 suned \
 limp
# Output file
!SunEd/!RunImage: $(OBJS)
    $(LINK) -o $@ $^ -mlibscl
# Object files
%.o: %.c
# Dependencies
-include d/*
The original SunEd makefile
As a brief overview:
And after
The new SunEd source tree
CP = copy
CPOPT = A~CF~NQR~S~T~V
SRCS = \
 suned \
 limp
APP = Apps/File/!SunEd
ROAPP = $(subst /,.,$(APP))
# Output file
build/!RunImage: $(OBJS)
# Object files
build/%.o: src/%.c build/dirs
    sed -f src/Version $< > $@
# Standard clean rule
clean:
    remove binary/zip
    remove source/zip
    x wipe build ~CFR~V
# Binary RiscPkg archive
binary.zip: build/pkg-dir
    remove binary/zip
    dir build.pkg
    zip -rqI9 ^.^.binary/zip *
    dir ^.^
# Source zip archive
    remove source/zip
all: binary.zip source.zip
build/dirs:
    cdir build
    cdir build.o
    cdir build.d
    create build.dirs
# executed.
build/pkg-mani:: build/dirs
build/pkg-mani::
build/src-mani:: build/dirs
build/src-mani::
# Copy over the static files
    x wipe build.pkg ~CFR~V
# Populate the RiscPkg folder
    cdir build.pkg.RiscPkg
# Populate the app folder
    create build.pkg-dir
# Dependencies
-include build/d/*
The new SunEd makefile
What it does
      s/__UPSTREAM_VERSION__/2.33/g
      s/__PACKAGE_VERSION__/1/g
      s/__RISCOSDATE__/28-Aug-18/g
manigen
out%=0
ON ERROR PROCerror
REM Parse command line args
SYS "OS_GetEnv" TO args$
REM Now the actual args
dir$ = FNgetopt
out$ = FNgetopt
DIM result% 1024
out%=OPENUP(out$)
mod%=FALSE
PROCprocess(dir$)
CLOSE#out%
END
DEF PROCprocess(dir$)
  LOCAL item%
  item%=0
  WHILE item%<>-1
    IF read%>0 THEN
      n%=20
      name$=dir$+"."
      WHILE result%?n%<>0
        name$=name$+CHR$(result%?n%)
        n%+=1
      ENDWHILE
    ENDIF
  ENDWHILE
ENDPROC
DEF FNgetopt
  LOCAL opt$
  opt$=""
  WHILE ASC(args$)>32
    opt$ = opt$+LEFT$(args$,1)
    args$ = MID$(args$,2)
  ENDWHILE
  WHILE ASC(args$)=32
  ENDWHILE
=opt$
DEF PROCerror
  PRINT REPORT$;" at ";ERL
  IF out%<>0 THEN CLOSE#out%
END
DEF PROCwrite(a$)
  LOCAL b$,off%
  IF EOF#out% THEN mod%=TRUE
  IF mod%=FALSE THEN
    off%=PTR#out%
    b$=GET$#out%
  ENDIF
  IF mod% THEN BPUT#out%,a$
ENDPROC
manigen
Makefile magic
Pattern rules
# Object files
build/dirs
build/dirs:
    cdir build
    cdir build.o
    cdir build.d
    create build.dirs
Explicit dependencies
Double-colon rules
# executed.
build/pkg-mani::
CP = copy
    remove binary/zip
    dir build.pkg
    dir ^.^
In closing
