- RPCEmu 0.9.5 (Gen:2)
Acorn Arcade forums: News and features: Testing on RISC OS
Testing on RISC OS
Posted by Charles Justin Ferguson on 08:00, 28/5/2021 | ,
Introduction
Where can you split code?
A way to split the code up
How do you test?
Is that really testing?
What about modules?
Ways to extend your testing
Finally...
You can find them here.
  9. build.riscos.online.
  14. (facepalm)
    The results:
    Pass94
    Fail264
    Crash0
    Skip104
