- RISC OS 'Advent' Calendar 2023 - Andre Timmermans
- RISC OS 'Advent' Calendar 2023 - ROOL
- RISC OS 'Advent' Calendar 2023 - Gavin Crawley
- RISC OS 'Advent' Calendar 2023 - Peter Howkins
- RISC OS 'Advent' Calendar 2023 - Amcog Games
- RISC OS 'Advent' Calendar 2023 - Chris Hall
Acorn Arcade forums: News and features: Native versus emulation in 2016 (Part 3)
Posted by Mark Stephens on 11:39, 24/12/2016 | ,
In Part2 of our speed comparison, I wondered whether there would be a signficant change to the figures from Emulation if we tried a different processor or screen resolution. So in Part 3, let us see...
1680 x 1050 in 32M, 32K and 256 colours for test 4
489562 275% 480160 269% 502375 282%
8569 5289% 8349 5153% 8828 5449%
2842 1174% 5033 2079% 8751 3616%
23098 1154% 19288 964% 23032 1151%
4950 317% 5209 333% 5309 340%
Draw Fill - Plot filled shape
5533 379% 6111 418% 6814 467%
HD Read - Block load 8MB file
586290 19660% 616427 20671% 618415 20738%
554164 18223% 502875 16536% 535318 17603%
FS Read - Byte stream file in
2613 1262% 2678 1293% 2681 1295%
1188 618% 1190 619% 1190 619%
It looks like Retangle Copy is significantly faster in 32K mode compared to 16M but otherwise we see little advantage on these tests (remember we get slightly different results every time we run the tests so we should not be concerned at small differences).
710 ARM versus StrongArm Processor emulation
501300 281% 498030 279%
8916 5503% 8723 5384%
2776 1147% 2726 1126%
23293 1164% 24660 1233%
5196 333% 4969 318%
5633 386% 5684 389%
583984 19583% 583984 19583%
510986 16803% 546133 17958%
2687 1298% 2643 1276%
1165 606% 1187 618%
So it looks like if your usage is similar to that measured in these tests, there is not a significant difference running on MacPro. As we suggested last time, this is a valid test but it may not be a fair comparison for your usage. And it only looks at raw speed not other factors which may be important to you such as power usage (Titanium easily wins), portability (you will want a laptop and should be comparing PiTop versus Mac) or ability to run macOS, Linux, Windows (MacPro is only contender).
There are other settings in the VirtualAcorn configuration file (VA.cfg) which may also be worth experimenting with. So what is your personal experience? And what settings are you tweaking for maximum performance on your Mac or Windows box?
