Acorn Arcade forums: News and features: Getting FAT32FS working on a RiscPC with a Castle USB Card
Posted by Jon Robinson on 13:57, 28/6/2014 | , , , ,
FAT32FS:Mount -v :0
Bravo, Jeff Doggett !!!
