!DualHead in use |
nytrex (01:15 11/9/2017) jimnagel (14:57 14/9/2017) arawnsley (20:31 14/9/2017) riscosbits (22:38 14/9/2017) Elesar (08:28 15/9/2017) riscosbits (09:43 15/9/2017)
Alan Robertson |
Message #124149, posted by nytrex at 01:15, 11/9/2017 |
Great to see developments like this. |
Jim Nagel |
Message #124152, posted by jimnagel at 14:57, 14/9/2017, in reply to message #124149 |
What happens when an error box pops up? It would normally be in the middle of the screen, so does it fall at the borderline between the dual screens? |
Andrew Rawnsley |
Message #124153, posted by arawnsley at 20:31, 14/9/2017, in reply to message #124152 |
There are pros and cons to both approaches - one big screen (eg. 3440x1440) on ARMX6 or dual monitor on TiMachine. For a start, two smaller monitors are cheaper than one 34" ultra-wide. As long as you use thin-bezel monitors, it shouldn't be a big issue. On the flip side, one big monitor is probably simpler for RISC OS . |
RISCOS Bits |
Message #124154, posted by riscosbits at 22:38, 14/9/2017, in reply to message #124153 |
[Edited by riscosbits at 10:40, 15/9/2017] |
Robert Sprowson |
Message #124155, posted by Elesar at 08:28, 15/9/2017, in reply to message #124153 |
That said, there's no "loss" of information - the error box just appears across both screens, with the mouse pointer restricted as necessary, so it isn't a big deal. In principle !DualHead could be extended to add a Wimp filter that spots windows trying to open centred, and move them to the left (or right).
However, using two inputs into the same monitor at the same time, and then employing the monitor's Picture By Picture mode, I have a native 3440x1440 display direct from the Titanium. Dell sell a quad picture by picture monster https://www.engadget.com/2016/05/23/dell-43-inch-quad-monitor/ though 43" may require buying a bigger house first! |
RISCOS Bits |
Message #124157, posted by riscosbits at 09:43, 15/9/2017, in reply to message #124155 |
Ultimately that's what RISC OS should do, either by having a nominated "primary" head on which notifications like error boxes always appear, or by picking the one where the mouse currently is - since that's probably where your eyeballs are. I really like the "where your eyeballs are" idea, but would prefer an option to not do that, in my "one screen" situation.
Dell sell a quad picture by picture monster https://www.engadget.com/2016/05/23/dell-43-inch-quad-monitor/ though 43" may require buying a bigger house first! And a bit added on to the mortgage! |
