- Wakefield 2001 show report
- Wakefield 2004 show report
- Wakefield 2002 show report
Acorn Arcade forums: News and features: The RiscStation Portable system
Flyer
Flyer
Click for more...
Click for more...
Click for more...
Click for more...
The Physics
The Onboard Screen
External Monitoring
Input devices
The Processor
  • A7000 (using the Arm7500)
  • A7000+ (using the Arm7500)
Operating system
Memory
Hard Drive Storage
The Docking Station
Power
Additional Information
  • PCMCIA Card 56k Modem
  • External USB CDRW
64 Mhz ARM7500FPE Processor
RISC OS 4 Operating System
64Mb 50ns System Memory
10Gb 2.5" EIDE Hard Drive
Luxury Magnesium Alloy Casing
8.4" TFT Touchscreen Display
77 Key Quality Black Keyboard
2 Button Glidepoint Touchpad
Built-In Stereo Speakers
1 x 3.5mm Mic In Jack Socket
2 x USB Connections
1 x Mini Serial Connector
1 x Mini Midi Port
1 x 10/100base Network Port
1 x 15Pin VGA Connector
1 x SVHS TV Output
1 x PCMCIA Slot
1 x IRDA Infrared Transceiver
1 x 20v DC Power Connection
Mains Power Supply Included
Portable Base Unit Only
999.00 + VAT
1173.83 Inc. VAT
1248.00 + VAT
1466.40 Inc. VAT
Additional Docking Station
249.00 + VAT
292.58 Inc. VAT
High Capacity Battery Stick
To Be Announced
Car Power Adapter
To Be Announced
RiscStation Ltd.
168 Elliot Street
Tyldesley
Manchester
M29 8DS
United Kingdom
Tel : +44 (0) 1942 797777
Fax : +44 (0) 1942 797711
