Acorn Arcade forums: News and features: How to fit a roguelike in 32k
Posted by Jeffrey Lee on 00:00, 11/3/2007 | , , , , , , , ,
After a bit of research, I came out with some minimum specs for the game. It should be able to run on a BBC Model B with the default 32K of RAM, and a 40-track floppy disc drive.
So the questions I need to answer are:
  1. What restrictions does the game need to work against?
  2. What data does a roguelike need to store?
  3. How can I fit all that data into the machine?
Restrictions
ModeTypeText resolutionMemory used
02-colour, full graphics80x3220KB
14-colour, full graphics40x3220KB
28-colour, full graphics20x3220KB
32-colour, full graphics80x2516KB
42-colour, full graphics40x3210KB
54-colour, full graphics20x3210KB
62-colour, full graphics40x258KB
7Teletext40x251KB
  1. An 80-column mode.
    This is the norm for a roguelike, but the BBC doesn't have any 80-column modes that also have colour. Colour is a useful feature to enable players to quickly identify items and monsters. Also, 80 column modes use upwards of 16KB of RAM - leaving very little (at most 9.5KB) for the game and data (The remaining 6.5KB of RAM is used by the OS, filing system, and BASIC interpreter).
  2. A 40-column mode.
    The black and white versions use less memory than the 80-column modes, but the colour version uses 20KB.
  3. A 20-column mode.
    These are only available in colour; the 8 colour version uses a whopping 20KB, but the 4 colour version uses only 10KB. But with only 20 columns of text to work with, the visible map area would be rather small, and I'd almost certainly need to add support for a scrolling map (something that could probably be done without in 40 or 80 column modes).
  4. Teletext.
In the end, it was memory requirements that won me over. Using only 1KB of RAM, Mode 7 was the obvious choice, leaving just over 24.5KB of RAM to store my BASIC program and its data. And although I wouldn't be able to provide any significant colour support for the target machine, there is scope for machines with more memory (e.g. 64KB) to use the 4-colour Mode 1.
Data to store
  • Static game data.
    This contains all the base stats of the items and monsters in the dungeon, including their names, appearance (a single ASCII character), and what class of item they are (weapon, food, monster, tool, etc.) This data will remain the same for every single game (Although the names of items may be randomized to add an investigative, discovery element to the gameplay).
  • The current dungeon level.
    This is the architecture of the dungeon, containing elements such as walls, doors, and stairs leading to the levels above and below. For the most part the dungeon is non-interactive, but most roguelikes support destructible terrain (typically the ability to carve passages through rock using a pick-axe). Although there is unlikely to be a pick-axe in my game, I do want to add support for destructible terrain, so it's important for the game to allow me to modify the map during play.
  • The items in the current dungeon level.
    This includes the player, the monsters, and all the other objects (food, weapons, etc.). It will also include all the objects the player and the monsters are holding. For each object, the minimal amount of data needed will be its type (player, laserdisc, cemtex mouse, pot noodle, etc.) and its location (either a coordinate in the dungeon or the ID of the player/monster that it is 'inside'). However I'm also hoping to store much more information - most notably the current health of a monster, the quality of a particular weapon or piece of armour, whether some food is poisoned or mouldy, etc.
  • The players' map.
    A traditional feature of roguelikes is that they employ line-of-sight - i.e. when you enter a level you only know about your immediate surroundings, and you cannot see anything that is behind a wall. As you explore the level your character creates a map of the level (either mentally or on a piece of paper), thus more and more of its structure is made visible to the player on-screen. So for each map cell I'll need two extra bits of information - whether the player can see it now, and whether he has seen it before. It is possible to store more information (e.g. the last known location of monsters, or the location of invisible monsters), but basic visibility information will do for now.
  • Other state variables.
    This includes the current game time (i.e. turn number), the player's score, experience level, dungeon level, etc. These variables will be added to the game as and when needed, since it's impossible to predict all of them beforehand.
  • Previous levels.
    I'm a big fan of persistent levels, so naturally I'll want the game to save the layout and contents of previous levels, so it will all still be there if the player needs to return at some point. This will basically involve storing the dungeon map, dungeon items, and the player's map. If needed I could cut this feature, but in my opinion it's a big part of what makes a roguelike a roguelike.
  • Bones files.
    These are stored on disc, and have a random chance of being loaded into memory when the player travels to a new level. A bones file is basically the dungeon map and dungeon contents for a level on which the player died. Typically games modify the item list slightly before writing it to a bones file - e.g. to transform the deceased player into a ghost, and to curse all his items.
  • High scores.
  • Static game data.
    Unfortunately some simple maths shows that DATA statements would take too much space. To store a one-digit number, two bytes would be required - one for the number, and one for the comma seperating it from the next field. A raw CSV export of the spreadsheet I was designing everything in came to 14K (A bit of an unfair test, but indicitative of how many items I'm hoping to include in the game). So, I set about designing a better solution (which will be discussed in detail tomorrow). Current tests suggest that it can squeeze the static data into about 4K of memory - half of which is the names of all the items.
    Having said that, the practicality of storing the game code, static data, high scores, bones files *and* save files on one 80KB floppy with a 31 file limit is questionable - once the game is finished I may advise authentic floppy users to store each savegame on a seperate floppy.
  • The players' map
    To store this, I only need two bits per map cell. One bit to flag if it's currently visible, and one bit to flag if it's been visible in the past. Rather than allocate a seperate buffer for this information, I'm going to make use of some unused bits in the dungeon map. There are only 31 different dungeon tiles, so the current map structure is only using 5 of the 8 bits per byte. Adding the players' map to that will leave one bit spare, which I can use for temporary calculations, such as checking which tiles should be blasted by an explosion.
    As stated it's a bit hard to tell how many of these there will be, so it's also impossible to state how much memory they would require. At the most, I'd expect them to use 1K of memory, but hopefully their requirements are so small that I don't need to factor them into any calculations.
  • Previous levels
    I've already revealed some of my plans for this - each savefile will be made up of fixed-size blocks (for ease of rewriting the data). The first block will be the header, containing the 'other state variables' and the player state (most notably the player object and his 52 private inventory slots). This will take around 400 bytes of space. Then for each level there will be the dungeon map (squeezed into 660 bytes, as we only need to store 6 bits from each byte), and the 202 dungeon items (1414 bytes), totalling 2074 bytes per level. Assuming I have an entire 80KB floppy at my disposal, that means I can fit 39 levels worth of data. As the game progresses I will decide on how deep the dungeon is, to hopefully ensure that the game code, data, high scores, and a full save file can fit on one floppy.
  • Bones files
    These are basically a stripped-down savefile, containing only the data for one level - so will be around 1964 bytes in size.
  • High scores file
Summary
  • 6.5KB used by the OS
  • 1KB used for screen memory
  • 4KB used for static data
  • 880 bytes used for the current dungeon level and player map
  • 1785 bytes used for the object list
Totalled up, that's about 15465 bytes - leaving about 16.5KB for me to fit the BASIC code into. This doesn't sound like much, and considering some of my plans for the game, I don't fully expect to be able to support all the features I want.
  Phlamethrower (11:55 11/3/2007)
  Phlamethrower (12:50 11/3/2007)
    fwibbler (17:55 11/3/2007)
      monkeyson2 (18:10 11/3/2007)
        Phlamethrower (18:23 11/3/2007)
          monkeyson2 (18:25 11/3/2007)
            Phlamethrower (18:28 11/3/2007)
        fwibbler (21:13 12/3/2007)
          Lampi (11:05 17/3/2007)
            Phlamethrower (11:52 17/3/2007)
Jeffrey Lee Message #99755, posted by Phlamethrower at 11:55, 11/3/2007
A progress update, then.
The load/save system, dungeon generator, time system, and simple player input/movement code is done. You can happily wander around levels opening and closing doors, looking at the pretty line-of-sight.
The code is currently hovering around the 10K mark, which is a bit worrying since the limit is 16K.
But more worrying is that it's all hideously slow when run on a BBC emulator. This is perhaps something that I should have seen coming, but I think focusing on the memory constraints first was the right thing to do. I'm now in the process of rewriting the code for speed, which unfortunately means removing some of the fancy features (Like proper line-of-sight).
Compared to the speed, the memory limits aren't so much of an issue at the moment. I can even squeeze about 4K more space out of the code by moving the level generator to a seperate program.
batr1.png 652x598 12.5KB
652x598
12.5KB
Jeffrey Lee Message #99758, posted by Phlamethrower at 12:50, 11/3/2007, in reply to message #99755
</rewrite>
It now runs at a decent speed. Hurrah!
It does take about 6 seconds to change room, but as long as you stay in the same room (and there aren't any monsters about) you can move about 3 squares per second. And even the room change time can be sped up further - maybe to 2 or 3 seconds.
fwibbler Message #99772, posted by fwibbler at 17:55, 11/3/2007, in reply to message #99758
fwibbler
Have you tried setting PAGE=&1200?
Phil Mellor Message #99777, posted by monkeyson2 at 18:10, 11/3/2007, in reply to message #99772
Will that affect DFS?
Jeffrey Lee Message #99782, posted by Phlamethrower at 18:23, 11/3/2007, in reply to message #99777
^ what he said.
But if it did work, it'd get me around another 1.5k to play with.
Also, are BeebIt and 6502Em both Wrong, or didn't the BBC have a cursor in mode 7? RISC OS machines and 65Host have a cursor, and I'm 99% certain the teletext chip supports it, but BeebIt and 6502Em don't show it (And yes, I do have the 'cursor' options turned on )
[Edited by Phlamethrower at 18:25, 11/3/2007]
Phil Mellor Message #99783, posted by monkeyson2 at 18:25, 11/3/2007, in reply to message #99782
I'm fairly sure it did have a cursor, but it possibly looked different to the ones in other modes.
Jeffrey Lee Message #99785, posted by Phlamethrower at 18:28, 11/3/2007, in reply to message #99783
Ah, upgrading from BeebIt 0.42.1 might help
Version 0.50 (12 Apr 2003)
- Added a cursor to teletext mode.
fwibbler Message #99856, posted by fwibbler at 21:13, 12/3/2007, in reply to message #99777
fwibbler
As I recall, unless you're planning to do something fancy with DFS then it shouldn't affect it.
It should still work for basic operating procedures.
Cheers!
James Lampard Message #100153, posted by Lampi at 11:05, 17/3/2007, in reply to message #99856
Lampi
I'm pretty sure it's actually 100K (-512 bytes for the catalogue)
I work it out as (40*10 *256) /1024 =100.
i.e. it's 10 sectors per track.
It's ADFS that uses multiples of 8 sectors.
Jeffrey Lee Message #100156, posted by Phlamethrower at 11:52, 17/3/2007, in reply to message #100153
I can't seem to find the website I got the information from, but I was rather uncertain myself whether it really was 80K.
