Acorn Arcade forums: News and features: Destiny Hints and Tips
It is often a good idea to leave a cache of heavier weaponry somewhere on a level which you can return to, and face enemies carrying far less. Dropping things like heavy missiles and huge mines is highly reccommended, as they impede progress somewhat. A good way to take on large groups of enemies is to simply carry a minigun and a few spare rounds.
