- Rounding Up February
- Iconbar in update shocker!
- Podcast 3 is finally out!
- Podcast 2
Acorn Arcade forums: News and features: Castle propose modifications to Iyonix motherboard [updated]
Links:
Motherboard modifications
Iyonix review
Update: STD/Simtec's offer
  (12:28 29/1/2004)
    ksattic (23:41 29/1/2004)
      monkeyson2 (01:33 30/1/2004)
        ksattic (03:11 30/1/2004)
          Horse (15:32 30/1/2004)
ksattic
Finally, an avatar!
ksattic
Finally, an avatar!
