- Iconbar in update shocker!
- Rounding Up February
- RISC OS magazines
- Podcast IV - coming soon!
Acorn Arcade forums: News and features: Alpha benchmarks, Omega tittle tattle
Posted by Phil Mellor on 01:46, 13/7/2003 | , , , , , , , , , ,
Alpha owner John McCulloch has posted some benchmarks, produced using RISCOSmark, to csa.hardware. "I got mine yesterday, it is very impressive, in all sorts of ways" says John. "It is very well made, and functioned as expected right out of the box".
The following table shows the results of the Alpha running RISCOSmark with Virtual Risc PC; John's 202Mhz Risc PC is included as a comparison, as well as the results provided on the RISCOSmark web site (note these are run in a less intensive screen mode, which is significant for computers without VRAM, such as the A7000+).
Machine (see below) Alpha SA202 SA287 A7000+ A4 Iyonix
Resolution, colour depth 1024x768, 32K 800x600, 256 (A4: 16 cols)
Processor - Looped instructions (cache) 41% 99% 141% 12% 5% 261%
Memory - Multiple register transfer 245% 98% 98% 83% 54% 201%
Rectangle Copy - Graphics acceleration test 169% 1149% 101% 66% 74% 5786%
Icon Plotting - 16 colour sprite with mask 51% 10% 117% 22% 9% 32%
Draw Path - Stroke narrow line 36% 40% 142% 16% 8% 101%
Draw Fill - Plot filled shape 50% 7% 139% 20% 10% 75%
HD Read - Block load 1MB file (Mb/sec) 99 1.8 3.3 1.9 1.3 18.0
HD Write - Block save 1MB file (Mb/sec) 66.3 0.75 3.1 2.0 1.2 13.8
FS Read - Byte stream file in (Kb/sec) 649 820 315 141 74 1101
FS Write - Byte stream file out (Kb/sec) 328 281 306 140 62 1020
Alpha 2.0GHz Celeron (VRPC) RISC OS 4.02 A7000+ 48MHz ARM7500FE, RISC OS Select 4.33
SA202 Risc PC SA 202Mhz, RISC OS Select A4 ARM3, RISC OS 3.1, 16 Colour greyscale
SA287 Risc PC SA 287MHz, RISC OS 4.02 Iyonix 600MHz, RISC OS 5.03, DMA enabled
What do the numbers mean? Well, the percentages compare the machine to a 202Mhz SA Risc PC running RISC OS 4.02 (100%). So 200% would be twice as fast as the "base machine". We haven't had chance to verify these (unofficial) figures, and it's worth remembering that benchmarks don't necessarily reflect use in the real world. Pinches of salt, and all that.
When John visited his dealer he played with a production Omega, and although he didn't run any benchmarks he "would guess it is about twice as fast as RiscPC overall till you use the disc drive, then wow it zooms."
While on the subject of MD and the Omega, Desk (MicroDigital Europe) reveal in their latest newsletter (translated) that MD had been secretly negotiating with Pace prior to Castle's purchase of RISC OS. Desk expect their first bulk shipments of Omegas this week.
Link: Alpha benchmarks
  (09:10 13/7/2003)
  mavhc (10:01 13/7/2003)
    ams (13:26 13/7/2003)
      flibble (16:00 13/7/2003)
        Revin Kevin (20:30 13/7/2003)
          monkeyson2 (21:02 13/7/2003)
            jmb (22:20 13/7/2003)
              moss (22:37 13/7/2003)
                jmb (23:13 13/7/2003)
                  flibble (23:31 13/7/2003)
                    hzn (07:40 14/7/2003)
                      andrew (11:39 14/7/2003)
                        not_ginger_matt (14:21 14/7/2003)
                          not_ginger_matt (14:30 14/7/2003)
                            hzn (16:27 15/7/2003)
g0tay Message #92407, posted at 09:10, 13/7/2003
Unregistered user Looks like RISCOSmark doesn't do proper harddisk benchmarking as windows is getting in the way on the VirtualAcorn box with it's caches, hence the 99&66M/sec (in memory) transfers.
Mark Scholes Message #92408, posted by mavhc at 10:01, 13/7/2003, in reply to message #92407
Why is the SA202 much slower than the base machine, a SA202, for Icon Plotting - 16 colour sprite with mask, Draw Path - Stroke narrow line, Draw Fill - Plot filled shape?
But much faster for Rectangle Copy - Graphics acceleration test.
Viewfinder?
Annraoi Message #92409, posted by ams at 13:26, 13/7/2003, in reply to message #92408
I was thinking the harddisk figures looked a bit odd alright (as the VA uses the underlying OS (host) to do writes then windows would step in copy the write to it's own memory cache - hence the exaggerated performance).
I don't suppose that will stop MD from claiming the harddisk access of the Alpha is faster than the Iyonix ;)
Regards
Annraoi
Peter Howkins Message #92410, posted by flibble at 16:00, 13/7/2003, in reply to message #92409
flibble
I wonder how you're getting the A4 to do 800x600 in 256, I thought the limit was 800x600 in 16 (or 640x480 in 256).
Kevin Wells Message #92411, posted by Revin Kevin at 20:30, 13/7/2003, in reply to message #92410
It does state the A4 16 colours.
Phil Mellor Message #92412, posted by monkeyson2 at 21:02, 13/7/2003, in reply to message #92411
Well, it does more clearly now :)
JMB Message #92413, posted by jmb at 22:20, 13/7/2003, in reply to message #92412
Is there any reason why the Iyonix was tested in 800x600@256colours?
John Hoare Message #92414, posted by moss at 22:37, 13/7/2003, in reply to message #92413
Indeed; isn't the IYONIX supposed to be *faster* in higher colour depths? Or have I misremembered?
JMB Message #92415, posted by jmb at 23:13, 13/7/2003, in reply to message #92414
RISCOSmark 1.01 (14 May 2003)
OS/Machine/Processor: RO5.03(update27)/Iyonix/80321@600MHz
Graphics Resolution: 1024x768, 16M colours
Processor: 258%
Memory: 209%
Rectangle Copy: 1544%
Icon Plotting: 217% (no, that's not a typo)
Draw Path: 104%
Draw Fill: 65%
HD Read: 18.1
HD Write: 13.5
FS Read: 1136
FS Write: 524
Food for thought ;)
Peter Howkins Message #92416, posted by flibble at 23:31, 13/7/2003, in reply to message #92415
flibble
Contractual Obligation Comment:
The Evil that is benchmarks
It burns my eyes.
Herbert zur Nedden Message #92417, posted by hzn at 07:40, 14/7/2003, in reply to message #92416
Wow, how did you do those IYONIX pc benchmarks? The harddisc values suggest that you accidently did them on a floppy disc...
I got
HD Read - Block load 1MB file 18249 = 611%
HD Wirte - Block save 1MB file 14054 = 462%
This is with RISC OS 5.03 and thus UDMA up and running.
Andrew Message #92418, posted by andrew at 11:39, 14/7/2003, in reply to message #92417
HandbagHandbag Boi
Did you say 'bullshit 'or 'bulkshipment'? ;-)
Richard Wilson Message #92419, posted by not_ginger_matt at 14:21, 14/7/2003, in reply to message #92418
jmb: You've missed the differentiation between Kb/second and Mb/second. ;-)
Richard Wilson Message #92420, posted by not_ginger_matt at 14:30, 14/7/2003, in reply to message #92419
And I've missed the difference between jmb and hzn. Oh well...
Herbert zur Nedden Message #92421, posted by hzn at 16:27, 15/7/2003, in reply to message #92420
Thanks for the clarification. I should get myself a bigger monitor since the on-screen display is pretty small and thus (or just by being illiterate to a certain extent) I didn't see the MB/s note. Error was thus on my side. Sorry.
