- Oldschool Reviews - SMALL
- Review - Target
Acorn Arcade forums: News and features: Oldschool Reviews - LASER
Posted by Jeffrey Lee on 09:00, 9/4/2007 | , , ,
The introduction
The game
The extras
The verdict
  Q (20:55 11/4/2007)
  Phlamethrower (21:03 11/4/2007)
    Phlamethrower (21:54 11/4/2007)
      Q (23:13 11/4/2007)
        Phlamethrower (23:53 11/4/2007)
John Cartmell Message #101268, posted by Q at 20:55, 11/4/2007
Jeffrey Lee Message #101270, posted by Phlamethrower at 21:03, 11/4/2007, in reply to message #101268
Jeffrey Lee Message #101271, posted by Phlamethrower at 21:54, 11/4/2007, in reply to message #101270
John Cartmell Message #101275, posted by Q at 23:13, 11/4/2007, in reply to message #101271
Jeffrey Lee Message #101278, posted by Phlamethrower at 23:53, 11/4/2007, in reply to message #101275
130 SYS &42 TO TEMP
130 SYS &42 TO TEMP
